Looks as though I may now have the 12v dying on me. Drove to Stirling around 21 miles, shopped moved another couple of miles, more shopping, then headed home. 15 miles from home all hell broke loose on the dash, bongs, warning lights and messages. It transferred to engine power, with the messages (not in order of appearance 'Engine Not Available Service Soon', 'Service Power Steering', 'Propulsion Power Reduced', Service Brake Assist' and 'Service Stabilitrak'. Warning lights were - 'Electrical parking Brake fault', ' Electronic Stability Control off' and 'MIL. Distance remaining on petrol was -- instead of the 46 it was before, Trips A and B were blank, Oil life was --. Car was still moving and then the power source went back to electrical and I continued home with reduced power steering, reduced braking, no speedo reading, no air con (windscreen was steaming up and I put the fan on low, air con was working on the way down) and no regeneration as though I was driving in 'N' but you could tell the physical brakes were doing all the work although the power flow did show regeneration.
Fault codes are:-
P0700 Powertrain
P079C Powertrain
U0100 Network
Pending codes:-
B2AAA Body
P0AC4 Powertrain
P2534 Powertrain Ignition Switch Run/Start Position Circuit Low
U1839 Network
U186A Network
U1876 Network
U1879 Network
I've charged the car for an hour, powered it up, engine started immediately and ran for a minute or so then it switched off. Took the car for a quick run and all working as expected only thing is the MIL is still on but I know that could go with a couple of good charges.
Fault codes are:-
P0700 Powertrain
P079C Powertrain
U0100 Network
Pending codes:-
B2AAA Body
P0AC4 Powertrain
U1839 Network
U186A Network
U1876 Network
U1879 Network
