1 - 20 of 339 Posts
Has anyone else experienced a flat 12v battery in their eNiro?
On Friday last week I came out to a dead car. I removed the 12v and recharged with a smart charger, replaced the battery and made a few short journeys on Saturday, Sunday and Monday.
This morning, dead again.
Are there any known issues, recommend diagnostics etc?
Sent from my Pixel 4 using Tapatalk
Yeah, almost every electric car I think has this. You need to trickle charge once a month. Did you leave it on overnight, or just a few minutes?
There's been some chat about this on the Facebook group.
If you check the settings (dash not infotainment)
Is battery saver enabled?
Sent using Tapatalk (I'm on my phone so sorry for any auto correct screwups)
Ummm no, definitely not. This is always a fault.
The Niro, as @Grant_H says, also has a battery saver option which more aggressively charges the 12V even when the car is switched off.
Typical reasons for this happening are a duff 12V battery or something plugged into one of the permanently powered sockets - at least one of the USBs is always on btw.
Normally you'll get a battery drain warning the following morning though. I had that once when the OVMS had crashed spinning.
It can also be a parasite drain - short circuit or similar.
That requires a dealer to diagnose but is a fairly routine check.
Even more rarely the 12V DC to DC converter (alternator equivalent) might be faulty and hence simply isn't charging your 12V battery.
My first leaf had an intermittent fault like that - probably a sticky relay - that took a long time to diagnose because of the intermittency.
tl;dr take it to the dealer to sort out
Did a full charge out of the vehicle.
I've had the car since September and this is its first hiccup
Battery saver mode checked and was enabled.
I think someone had a flat battery at a campsite, and identified it down to the key being close to the car which kept getting ready to unlock through the night.
So would be careful of that too. Not saying the reason in this case, but additional to @MetalHead s comments
Iirc it was people who had battery saver on that were seeing the issue, but it's on the me and so far (touch wood) no battery issues
As @MetalHead says get it booked in at the dealer. Hopefully a known issue and they will get you sorted out
A bit of light reading from the Kona forum!
John.
Discussion Starter #10
John.
Wow that was a long read. I've ordered a cigarette lighter battery meter to see if it gives any pre warning. Will keep an eye on it ...
No answers really but some discussion of this here:
Reactions: MetalHead
Sounds like your battery is knackered then. I think that once a battery won't even trigger a few relays, it's time for a new one. (Keep the new one trickle charged regularly.)
It's crazy since what's going to happen when you go on your 2 week summer holidays and arrive back to your airport ?
Let's face it too, the cars have been stationary on a boat for up to 5 weeks, and then another good month or so between Immingham and dealerships
After reading about these issues on more than a few EV’s - I have bought one of those compact booster packs to keep in the boot of my car !.
I have always kept a set of jumper leads in the boot of most of my other ICE cars in the past.
The power pack will hold its charge for almost 12 months.
It takes very little space in the boot of the car.
I do have break down cover, but the power pack could have you on your way in only a few minutes.
The recovery services could take over an hour to get to you.
Which one did you buy and where from? Seems sensible to me! Though they tried on Mr EV’s car above with one of these and it wasn’t enough appparently.
Reactions: Carty
Dont keep it in the boot, as boot might not open / unlock when battery goes flat. People have said they needed to use the actual key to unlock car, as fob wont open / unlock the car.
I don’t think we have any alternative other than using the boot really ??.
It’s okay if the battery runs flat while at home.
Then, I can keep it in the house.
But not much good if the battery runs flat away from home !.
The manual key can give us access to the interior of the car, does that open the boot as well ?.
If not, the pack could be put under the drivers / passengers seat I think.
1 - 20 of 339 Posts
