1 - 7 of 7 Posts
Does anyone have experience of using this with the utility mode, eg for camping? Could you power a light with it? Anything else?
Thanks!
I use it with an air pump for my inflatable boat with no problem. I think the outlet is rated 10A (it's in the handbook somewhere) so should be fine for a light. If you have LED lights they pull very little current, so it'd probably run several.
I think it's marked "180W max" actually by the socket, which is about 15A. You can certainly power any light you want with it, basically anything that doesn't involve heating (unless you want to wait a reaaaallly long time to boil a kettle :) )
Reactions: yclaire
If it is 180w its more like 0.75A…….
1 - 7 of 7 Posts
