1 - 7 of 7 Posts
Can anybody tell from the markings whether this is a 16A or 32A Type 2 / Type 2 cable?
It's from my E350e but now lives in my wife's i3S. I used it at the weekend in the Westgate Oxford and noticed the i3S was only charging at 3.6kWh. Zapmap and the Westgate say the chargers are all at least 7kWh. I suspect the cable is the reason why I wasn't able to pull 7kWh.
As my own car only charges at 3.6kWh max I wouldn't have noticed before if it is a 16A cable.
127679
Deleted - server threw a wobbly & flagged a fault, but still posted! So I re-posted...
Put a meter across (I think) the PP line and the Earth line at the charger end of the cable. You should see 1500/680/220 Ohms, depending on whether the cable is rated 13/20/32 Amps acc to IEC specs. So expect 680 Ohms if a 16A nominal cable, else 220 for the beefier 32A one.
Reactions: Weebull
3G2.5 from the photo means 3 x 2.5mm^2 conductors which will mean it will be rated for 16A continuous usage. My 32A cable says 3G6.0, ie 6mm^2 conductors
1 - 7 of 7 Posts
