1 - 13 of 13 Posts
Hi, I would like some advice about upgrading my Ford Focus conversion from lead acid batteries to Lithium and a BMS. What batteries, and BMS, how much and how many? Where can I get everything. I want to increase my mileage so I can travel at highway speed to nearby towns- 15 to 20 miles away. The lead acid batteries are just too heavy and old and won't make it. Need to recycle the batteries and upgrade my system. Any suggestions would be very helpful.
Automotive parking light Wheel Tire Vehicle Car
My honest suggestion here is - don’t bother. Get a second hand Leaf with at least 9 capacity bars left and you’re sorted. It’ll do what you need and be better than your focus in every single way.
Outlander
I thought the Focus BEV shipped with lithium batteries? How did it come to be powered by lead acid?
Lithium battery alternatives to LA have their own BMS built in so you can just swap the LA for a larger capacity Li-on. E.g:-
This. The batteries and effort will cost significantly more than a usable used Leaf.
Not necessarily. The energy density of a Li Ion battery is much greater and the weight much less. The 150ah battery on the ebay listing weighs only 16kg, a LA battery of the same capacity would be around 30-60kg.
However, the OP hasn't said how many batteries he has so it could get very expensive.
If you do want to keep it, then buy a used pack from an EV. Volt packs are popular for conversions for instance. How you configure it all will depend on how the existing system is designed, eg voltages etc.
DIYElectricCar forum might be the place to look.
Sorry it's pie In the sky. You can get a usable Leaf with his required range for less than it will cost to retro fit this properly and make it usable.
A leaf will be a much better car as well
It's better to say how it is and knock stuff like this on the head.
ID.4 GTX & M3 LR
Come on, of course it’s not pie in the sky! 😁
Perhaps they don’t want to buy a Leaf?
I’m not saying it’s necessarily sensible either, or even straightforward, but I think anybody who converts a car to an EV (or even as in this case updates it to keep it going) deserves a bit of encouragement!
I think @farmergiles was on the right track.
EV6 GTLineS RWD
Quite.
The world needs people who are prepared to do different and interesting things, even if they make little sense to others.
Unfortunately OP, I can offer little advice other than keep going, if you want to.
1 - 13 of 13 Posts
