1 - 20 of 31 Posts
· Registered
Hi guys - currently weighing up my options with getting the Golf GTE and haven't been able to find much info on the Battery life when using hybrid mode. From what i've read it will last about 30-40 miles on EV only but im curious as to how long it would last if i'm also using petrol and what kind of MPG I could expect. Basically weighing up between this and a Diesel.
I'm also curious on your opinions of whether a GTE would be suitable for me.
Current commute: 120 miles per day (60 miles each way)
Charging point at work only
Mostly motorway with some country roads for the last 20 miles
Does anyone have experience with this car? Cheers!
· Registered
Kia Soul EV 2020
MY16 GTE will not do anything near 30 EV miles.
Best will be 24 on a good day.
Now with the efficiency (get a charging point installed at home!), you will get about 80 or 90mpg on the 100-0% run. On the EV empty run you can probably get something like 50mpg.
If you get charging at both ends, the GTE will easily win over a diesel. With only one charge, you will need to be very good with your EV use and optimise it. I still think the GTE will be better, but it will be close especially in winter.
· Registered
2021 BMW iX3 Premier Pro / Nissan Leaf 2021 e+tekna (ordered)
It will depend on the exact one you get, they range between 8kwh and 13kwh battery packs. The 13kwh one get about '30 miles' (VW quote) .
My 225xe is 10kwh and I used to get the 25 miles to work and 25 back just about (warm months) and it's range is around that, but that's not motorway speeds that's backroads with little traffic.
I'd say on motorway (judging from mine's range at motorway speeds is about 15ish) I'd say 20ish miles on motorway.
Then it has the standard VW 1.4, which isn't bad on efficiency.
So If you get a 13kwh one that's what you will get, if getting the 8.7kwh one then extrapolate down...
· Premium Member
Thanks for the info - How does it do in hybrid mode? Any idea how many miles you would get out of a full tank + full battery in hybrid?
Think of the electric motor in hybrid mode as a ‘fuel multiplier’, ie it will make the most of your fuel by assisting the ICE when driving.
Depending on how you drive, you should achieve 45-50mpg.
However, you can get that sort of mpg from a regular petrol Golf (or other modern ICE car) albeit without the performance of a GTE. If you use that performance then you’ll not get the 45 mpg either.
The key thing is, you really need to be able to plug it in at home as well, otherwise you’ll be relying on just the work charger to help with your journey home or even worse using petrol to charge the battery, which is nonsense.
Plug in hybrids need to be plugged in and charged as much as possible, otherwise there are better options.
· Registered
Discussion Starter · #7 ·
Yeah that's kind of what I expected - So potentially a diesel may be abetter option anyway
· Premium Member
I couldn’t in all conscience recommend a diesel these days, but with home charging an EV could work well for you with those mileages.
As ever, it depends on your own circumstances, budget, home charging setup/possibilities etc.
· Registered
Leaf 30kWh, HS PHEV
For a 120 mile daily I would stay away from Phev. If you have guaranteed charging at work you could get about EV from Leaf30 to e Golf etc. If you don’t want to be bothered with work charging I’d get Leaf40, Zoe40, MG ZS etc.
You could always get petrol / diesel if you don’t want a full EV
· Registered
Discussion Starter · #10 ·
It's an awkward one as the charger would have to be set up out the front of the house which is on a road. Our car parking is at the back (behind the garden) so there's no way for me to put a charger where we park. I'd have to use it out the front of the house.
· Registered
All depends, if you can charge at home (even off granny) and at work it may be a bit better, and you get the instant torque of the leccy motor. On the 225xe I get 50's on average (but that's a turbo 3 cyl not a 1.4) and when you want fun sport mode is proper quick to 80 (where electric turns off)
So all about what you want.
· Registered
Discussion Starter · #12 ·
e-Golf was another option I was looking at - Need to do a bit more research into them though and I'd be hesitant to be relying just on the Battery.
· Premium Member
How long is your garden? I‘ve got a 25m+ cable run from my consumer unit to the charge point, then another 10m of cable from that to the car?
· Registered
E gof has 140ish mile range quoted, so think of it as 100 in winter, so should be ok for you as long as you can charge both ends. Look into the olev grant to see if they would cover install of charge at the back of house.
Or outside of VW lots of options for 150ish mile range cars.
· Premium Member
Between the end of our garden and our parking spots is our neighbours two spots. So it would effectively have to trail across his space which is a no go.
Ah ok, sounds awkward then and would necessitate trenches or attaching to neighbours fences/walls or running along the edge of their spaces.
Not impossible, but depends on your relationship with neighbours etc.
· Registered
Ouch no olev grant then. But I'm in same situation can't get grant and chargers are not super bad. But like everything, have to do what's right for you. If you go with something with decent range though, you could charge at work and not worry about home, then use fast charger around you for other times?
Suppose depends on budget and whether you really want a VW or dont mind.
· Registered
Discussion Starter · #18 ·
Yeah something like an ID3 would work because it has such a high range - But then the car itself is going to cost a whole lot more :D All fun and games.
· Premium Member
Agree with this, an e-Golf would struggle with the 120 mile round trip from work to home and back to work, but a 58 KWh ID.3 would do that no problem year round, as would a myriad of other EVs if you‘re not wedded to VW.
Something like the latest Zoe would be a good option.
1 - 20 of 31 Posts
