1 - 6 of 6 Posts
Hello.
I would like to ask for some advice. I recently have 2018 Volkswagen Golf Alltrack!!!
I've been using it for a few months now, but I've noticed that the stereo is starting to get a little slow some time initially did not pay attention, but it happens all the time.
I went to a specialist and was told that it is necessary to replace the device because there is damage. I don't know how to be a new original is expensive. I think maybe I should replace it with Android. I saw that on Youtube. Can help with that situations? Some time radio doesn't work and I don have the sound in general for few seconds.
Hello.
Hi saraluis64! I kindly disagree, at least at first sight. Before replacing a device, which is unlikely to be damaged (considering it has no impacts or possibility of easy physical damage), I would always go with the software side.
Consider a factory reset. A clear of cache would be the first step, but a factory reset would serve you as a clean starting point, and see how it behaves from then on. If the problem would reappear, I'd go with a firmware update. These two steps are way more reasonable than changing the whole hardware.
Hope it helps, but let's see if any other fellow comes up with solutions or experience.
Hello! Yea with some kind of hybrid system or for example eclectic car is can be an issue .. always have to check twice
Hello.
Hi.
You know before I buy my ex-car I have the same problem as in your case telling. And yes I also decided to install the android and it was not a bad decision. So like for me it was a good option a lot of apps and possibilities but don't buy some cheap ones because on the future it will be the same problem with it. So it was my experience. Hope I helped you
. It was Toyota highlander hybrid 2018 and I don't have any problem at all with it
Hi.
Hi!
Sound good can you tell me the name of brand or some link.
I will be really appreciated. ;)
Hi!
I will be really appreciated . ;)
Hi, again)
I found with a lot of effort in my email about a smarty trend order winch I made a long time ago.
A lot of things have changed now. Technology is changing all the time check out their website.
I hope I was able to help you, I was based purely on my experience.
1 - 6 of 6 Posts
