1 - 19 of 19 Posts
My Passat GTE Advance has gone in for its first service today.
First registered December 2019. They are saying it needs the battery removing and checking as part of recall. I am aware of this.
I thought this recall was for older vehicles not the newer 13KWH Passat's and Golf's ?
Anyway wont see my car for a week now :(
Also they only told me about the recall when I arrived to book in.
Discussion Starter · #2 ·
Just spoke to the dealer this recall is different to the Golf one. They are dropping the battery and checking the HV battery plug seal. Apparently water is getting past this seal in some cases.
If water has got in then its new battery time !
Mind you it would be good if they replaced the infotainment system as well because mine is pants.
Apparently there were issues migrating Passat database to new system and WeConnect working more intermittently than usual, so once got my "Globe" icon lit up again on MY20 received a couple of MIB 3 OTA updates one after the other, so fingers crossed for you.
Mine told me they needed it for 2 days - a week seems a bit extreme!
VW Passat GTE
When I spoke to tech support about this, they suggested using the website instead of the app. I was skeptical, the website has always worked first time (with one exception, where it worked on the 2nd attempt), even when the app is going through one of it's "episodes". Which makes we wonder if they're running two separate systems... the really odd thing is that I had a grey Globe icon for a few days, but it magically lit up after using the website for the first time - no idea if the tech support person did something behind the scenes, or the website did something that fixed it, or it was just coincidence...
VW Passat GTE
Infotainment system no fault found so it will still be pants.
Out of curiosity, what problems do you have with the infotainment, and which version do you have? I have Discover Media (not Pro), and it takes a week and a half to start up and is an absolute fingerprint magnet, but otherwise seems fine.
VW Passat GTE
I think its the discover pro. The car is an advance.
It switched on and off on its own. Jumps media tracks. The screen goes blank. Its unresponsive sometimes.
Wowzers, that's disappointing... not seen any of that. My previous Passat's infotainment system (RNS-315 I think...) had those problems though, really annoying.
1 - 19 of 19 Posts
