Your house has a 3 phase supply? That's unusual. Did you spec it as part of a self build?Pretty sure Rolec will do one. I had mine wired for 3 phase from the house when I had it installed, on the basis that I would only need to change the module and hook up the extra wires (or get a sparky to do it) when I get a car that will benefit from it.
No, it's a barn with an ancient but rather good electric heating system. I didn't realise I had 3 phase until I had the survey for the charger.Your house has a 3 phase supply? That's unusual. Did you spec it as part of a self build?
Only Zoe (of the currently available mainstream EVs) goes as far as 22kW. Older Tesla Model S did 22kW if an option was purchased; newer ModelS and Model X only go to 16.5kW with the option.This is only worthwhile for Zoe owners isn't it? Does any other BEV charge at 22kW+ AC
Tesla and new i3 both do 11kW on 3 phase as does B Class. Very useful for B Class as only 3kW with single phase.This is only worthwhile for Zoe owners isn't it? Does any other BEV charge at 22kW+ AC
