Mark your current one first, then you will know.I think i get a new pollen filter as well.
Not sure its ever been valeted or wash at a dealers before, we shall see
What do you mean?Recalls as well...
They will plug the car into some diagnostics that will probably do some kind of re-balance across the cells and check voltage - they will use that as battery maintenance.They can't force you to use the dealer to keep the warranty. As long as it's serviced properly and using suitable parts it doesn't affect the warranty.
Anyway they don't do any maintenance on the battery, it doesn't have oil to change or anything.
Recalls can be done without getting your car serviced. It does represent another trip to the Dealer, but it doesn't have to be at the same time as the service.Recalls as well...
Exactly that, why visit a garage twice? Once in a year is pain enough!As above - the battery warranty is something that is outside of the rules on servicing as they have not released the kit at a reasonable price to allow others to service it.
They won’t do any cell rebalancing, the BMS takes care of this.They will plug the car into some diagnostics that will probably do some kind of re-balance across the cells and check voltage - they will use that as battery maintenance.
The 36000 mile service at 3 years doesn't have the brake fluid change, its at 2 years then 4 years,As I understand it, the 36,000 service includes brake fluid change.
