1 - 4 of 4 Posts
Last weekend our 19 month old (12500 miles) 38 wouldn’t charge. Had to get breakdown out to it and it eventually ended up being taken by truck to a dealer on Monday. Today we were told the charger lock solenoid has been replaced and we can collect it.
hyundai organised a courtesy car via Thrifty but I’ll just say that wasn’t as smooth as it could have been.
Going to pick it up tomorrow…….92 mile round trip as our closest dealer didn’t have any capacity to sort it.
Just glad we weren’t on one of our regular 900+ mile weekend round trips to Scotland from South Wales when it broke.
Ioniq
This happened to ours a while back; evidently it's something that is more common than it should be! We were very lucky in that we still had (just about!) enough range to get to the nearest dealer after we realised what was going on. You're right, it's a simple thing but could be a show-stopper if it happened away from home.
I have the same issue I think.
Tested with home Rolec charger. Also the 3 pin charger. No apparent faults with either charger.
Yesterday I got as far as all three blue lights on the dash flashing together - a charge fault indicator I believe - but today it won't even give the error indicator ;
Automotive parking light Hood Rectangle Font Window
App also reporting a fault as follows ;
Font Rectangle Screenshot Parallel Number
Hyundai Roadside Assistance (the AA) have been unable to help - we disconnected the small battery for 15mins - no change once reconnected.
So off to the dealer I guess before it is totally out of charge !
Just found this in the IoniqForum ;
"Edit, I just found the charger release that I pulled wasnt the right one, and theres another charger release pull under the boot lining, which I've just pulled and thats worked, the cars charging again now"
and also ;
"If you search the EV section of this forum you will find a number of threads that discuss the issue of the charger cable lock failing to operate. The car will not charge until this has activated correctly and locked the charge cable plug in place.
Mine has been replaced under warranty, Twice, and has given no problems since. I noticed that after the first replacement it required quite a strong pull on the manual relaease lever to get it to release, however, after the second replacement it requies only a light tug and feels much smoother.
This is a recurring issue and if it happens to you again I suggest you take the car to the dealer and point out that it is a know problem."
and so I'm pleased to report that this appears to have worked for me and the car is charging again. However I am still curious whether this is an indicator of a problem with the charger lock solenoid which will only get worse ? I could then get it sorted before it leaves me stranded !
1 - 4 of 4 Posts
