1 - 16 of 16 Posts
£200 + p&p, or pickup from Oxford
Used for 18 months similar to the one in the photo:
WallMounted charging unit suitable for charging all Mode 3 electric vehicles, ideal for home charging.
Rolec is a British company with a factory in Boston, Lincolnshire. They have over 65,000 charging points in use currently.
Believed to be the lowest priced full Mode 3 fast charging unit in the UK
Eligible for OLEV Grant Funding under the Domestic
Home Charge Scheme
Includes overload and fault current protection (RCBO)
This modern, attractive unit is available in a variety of colours
Has been certificated by the BSI as safe to use
in the domestic environment
Easy to install and maintain
IP65 weatherproof
Corrosion resistant
UV stabilised
Incredibly hard-wearing
CE Certified
Electrical
J1772 (Type 1) charging gun c/w 5m tethered lead and lead holder
Charging gun holder included in unit
Available in both 16amp (3.6kW) or 32amp (7.2kW) charging options
Mode 3 IEC61851-1 compliant communication protocol
Built-in LED charging status indicator
Built-in 20amp or 40amp, 30 mA Type A (DC sensitive) RCBO accessible via an IP65 rated access door providing overload and fault current protection
230V AC/50Hz
Full internal wiring – ready to install
139935
Thinking of getting a commando fitted and using the ohme charger. Any difference if I ask electrician to install instead?(With earth spike)
I've just dropped you an email to the email address on your google drive link if that's the correct one!? - I wasn't able to reply back to your private message as my account is new!
Discussion Starter · #13 ·
yeah the device is build for charging, it's tethered so no dragging the commando to type2 cable out which is extra..... quite a bit
1 - 16 of 16 Posts
