I took my Leaf in to Ancaster and asked the salesman if the cable I had fitted externally from my new Nextbase 402G camera could be hidden as i t was a bit of an eye-sore running down from roof to the bottom of the windscreen and then back to the door rubber from where it was hidden on its way under the floor mat and up to the central cigarette lighter point. He summoned an engineer, and within 5 minutes, with no tools he had fitted the cable inside the plastic moulding that runs from ceiling to the dash. Now all that is visible is three inches of cable that exits the roof over the mirror and fastens to the windscreen suction mount.
NOTE, because of the GPS antenna on the inside if the windscreen behind the mirror it is not possible to hide the camera very well as the suction will not work on the knobbly surface.
