1 - 16 of 16 Posts
Been playing around with it in advance of a long-distance trip in our ID.3 Tour. It puzzles me that ABRP never seems to be willing to give me the shortest and most straightforward route (Coquelles/Reims/Nancy/Colmar) and instead routes through Belgium (Coquelles/Lille/Namur/Luxembourg/Metz/Strasbourg/Colmar). The route is considerably longer and requires more charging stops. I tried different times of day so it is not connected to traffic, and does not seem to be connected to charger availability (preference set to Ionity). Google Maps consistently goes for the French route via Reims and then Nancy when checked at the same time, which is almost 100km shorter.
Any ideas what is going on here? Is it trying to avoid French motorway tolls?
The distance from the Ionity charger south of Reims to that north of Colmar is 309km on the shortest route, which should be quite doable on the Tour?
Many thanks in advance!
All the best
Andreas
Eurotunnel terminal Coquelles, then either one charge at Aire de Rely or prior to boarding at Ionity Exit 11 on the M20, depending on traffic out of London. I guess the key question is the reliability of the Aire de Champagne Sud charger. Using Ionity at Aire de Gueux west of Reims adds km and time.
All the best
Andreas
i3 120Ah->Kona 64kWh->e208->ID.3 Family->Model 3 60kWh LFP
It looks like it’s because it’s allowing for a 3rd charging stop if you force it to go via Reims. Going via Belgium only requires 2 stops.
(Starting from London with 100%)
147718
147719
Thanks both, got it. The Tour has the 77kW battery set, and I do indeed get exactly the route that is shortest if instead I enter a Model S 2021 Long Range into the system.
So yeah, better not be too optimistic over the legs...
All the best
Andreas
In reality, there’re are a multitude of factors that could make a different route preferable to another on the actual day..traffic, weather forecast & especially headwinds in certain areas, reported charger failures etc.
Weight apparently makes very little difference except on sections of a route involving significant elevation change (or I expect lots of stop start traffic).
147727
Thanks for taking the time to check and taking the screenshots, much appreciated!
All the best
Andreas
No problem. If you haven’t already, check out the Tronity app/service which you can link to your VW ID account and to ABRP to get the battery % updated automatically in ABRP.
I have done the Nancy - Colmar route a few times but it is not one I would choose; Reims, Metz, Strasbourg is fastest and simplest (although we usually cut out Strasbourg and overnight at Obernai). BUT, that’s in a diesel motorhome so probably not helpful! We prefer the Autoroute toll roads as they are better equipped and I would have though are well provided with charging points.
Discussion Starter · #16 ·
Thank you so much! I like the tolled autoroute because at least in the past you tended to get fewer trucks than on the other routes.
All the best
Andreas
1 - 16 of 16 Posts
