1 - 20 of 37 Posts
· Registered
I'm finding that regen zero, using the regular brakes and maximising coasting is achieving the best efficiency I've seen in the past 2500 miles. Shame your can't default lv0
· Registered
Interesting. Thanks for sharing. I assume you mean the regular brake pedal - surely the car still uses regenerative braking till you press harder?
· EVEZY code d55d6 *** Try my car cost calculator
i3 120Ah->Kona 64kWh->e208->ID.3 Family->Model 3 60kWh LFP
It should be the most efficient way of driving given the inefficiencies involved with regenerative braking.
It’s just a matter of balancing maximising efficiency by coasting more and not being too much of an annoyance for other road users.
· Registered
Yes, foot pedal brake.
I've turned auto regen off as I think it's a bit over cautious and causes me to have to use the throttle to recover speed.
On long hills I'll enable lv1/2 again to save my foot.
· Registered
My experience is that it is a matter of right foot control. In town and mountains I very much prefer level 3, since it allows for 99% one-pedal driving. Especially in up and down road, not having to move my foot is just so more relaxing and by varying the regen level I can approach corners very smoothly.
On the motorway I almost always use SCC but when using manual controls, I also find I can coast by giving just enough throttle to stop regen from kicking in. It's a matter of habit I guess.
I'm sure I am a nuisance to the other road users Bill as I'm trying to stick to the twenty limit! (Well just a bit over perhaps)
Yes I know the feeling!
· Registered
Kia Soul EV 2020
@Xinix please don't confuse things. Any regen or one-pedal driving is simply a user interface. It is not the best, most efficient way of driving, which is the topic here.
· Registered
2020 VW ID3
Not so much habit as developing that skill with the sensitive use of the right foot. Then it becomes a habit.
Nice to learn a new driving skill.
· Registered
As I mentioned, you can also coast by throttling the accelerator so what I meant is that you can achieve the same behaviour / efficiency by using the right foot wisely rather than setting a specific regen level.
· Registered
Kia Soul EV 2020
No, you can't, as far as efficiency is concerned. Get used to it that's fine, it is you choice. But it doesn't mean that you have improved or managed to do something better. It is a simple user interface, and it doesn't change the fact that efficiency is better under coasting.
By the way, "throttling the accelerator" is not the same as not using the accelerator. Just look at your car's energy monitor.
· Registered
Efficiency is entirely the wrong term to use. The amount of energy expended on a given route includes the traffic conditions, over which in general you have no control. Driving a car around an empty test circuit is NOT the same as driving a commuter route or even a motorway where there are random external events like cars in from slowing, braking, cutting in, give ways, merging etc. So don't use the term efficiency, it just indicates your lack of understanding.
· Registered
It is definitely possible to have regen level 3 set and keep the accelerator in a position to cancel out the regen to effectively use 0 kWh and thus be coasting. I never said I had improved anything or managed to do something better. Those are your words and your interpretation of my post.
1 - 20 of 37 Posts
