Presuming that you can charge at home, the next charge point you will need is after a 60-70 mile journey. Don't forget that you will normally leave home with a full 'tank' which is normally enough for all local journeys, you can 'top up' everytime you are at home. As long as you have enough to get home you will always be fine.
My LEAF is just coming up to 20K miles, nearly all charging has either been on my driveway or over 25 miles from home at motorway services as I travel to other towns, etc. My only regret, for my life style, is that I did not get the 6.6 onboard charger, That said, I have had no prolems with a combintion of slow 3kw charge at home and rapid charging when away from home.
Look at sites such as Zap Map, you will see plenty of charger points are out there, with more coming each week.
