1 - 14 of 14 Posts
· Registered
Hello all. My car just arrived with cables.
One is a 1P 230V, 10A 2.3kW - regular home and they also provided a 3P 400V, 16A 11kW. I thought the latter would plug into the red socket in the image below, but I was wrong. Does anyone know of an adapter I can order?
I'm searching, but not sure what I'm looking for.
Help appreciated.
Thanks!
139909
· Registered
Depending on the rating of each phase of the 3 phase is (I.e. if it’s 32A per phase) you could also get a cable that plugs in and gives you a 32a single phase outlet.
you could charge at 7kW with a standard single phase portable EVSE.
3 phase EVSE’s are pricy!
What car are you planning on charging from it?
· Registered
That will be fine to charge a polestar and that’s ad fast as you will be able to charge it AC, it’s a bit pricey though.
I’ve done a quick conversion from Swedish Krona to GBP and the one you have specified there works out at £600.
I’ve done a quick search and this is basically the same thing for £400
I’m not sure if they ship to Sweden but you may want to shop around.
· Super Moderator
I'm guessing so. The box was there when I moved in.
Just asked an electrician friend.
And thanks!!
That box has rather a lot of connectors on it. Could we see where it’s sited and what connections go in/out of it?
· Registered
Any box with that many outlets on it surely has a big incoming supply cable.
It looks like it was intended for commercial use is on a caravan site or a farm or something like that?
How big is the cable feeding it and where is it fed from?
What is the rating of the 3 phase breaker that supplies it?
· Registered
MG ZS EV
They don’t ship out of uk but I recognise the brand and you should be able to get it via AliExpress direct from China or via an EU country.
· Registered
Helo everybody,....first post here... due to thinking of buying a used EV and working now for requirements, also have this 380V connection.
So I found this cable.. I hope this will work.
139958
Aliexpress 200 eur
And will put it in this outlet. (that I will connect directly to my 380V 3 faze plug.)
139959
Will this work?
(Thinking of BMW i3 94kWh)
· Registered
MG ZS EV
Aliexpress 200 eur
Will this work?
Should work fine, but it is 16 amp and on single phase cars will charge at 3.6 kw.
1 - 14 of 14 Posts
