I have the Enyaq, based on the same platform, and this is the default behaviour. The speed limiter is not active by default, but it is set to adjust based on signs.
I have the Enyaq, based on the same platform, and this is the default behaviour. The speed limiter is not active by default, but it is set to adjust based on signs.Currently awaiting delivery of my ID4 and I'm just trying to suss out whether you can set the speed limiter to read the road signs/use mapping data to set the limit, similar to how it would for the ACC?
So you'd flick the limiter on, and it would then default to the signs rather than user input?I have the Enyaq, based on the same platform, and this is the default behaviour. The speed limiter is not active by default, but it is set to adjust based on signs.
Yeah, that should work. Although it's worth noting that the speed limiter doesn't use regen to maintain speed downhill, it only prevents application of power.So you'd flick the limiter on, and it would then default to the signs rather than user input?
Yes, that's right. (Actually I'm not clear on when it uses signs and when it uses information from the mapping data.)So you'd flick the limiter on, and it would then default to the signs rather than user input?
I hadn't realised this. I'm sure that the speed limiter does control speed when going downhill - are you saying that this is achieved by using the brakes rather than using regen?Yeah, that should work. Although it's worth noting that the speed limiter doesn't use regen to maintain speed downhill, it only prevents application of power.
I usually use the ACC for maintaining speed downhill as it does use regen.
You don’t need to press kickdown to override an erroneous speed limit, merely press the accelerator gently to recover to whatever speed you desire.Although you can override the limiter by using kick-down this is perhaps not always appropriate, and is not necessarily appreciated by any passengers.
I originally read the manual for the Enyaq and thought it explicitly stated that the speed limiter does not control the vehicle speed and if you want it to slow down you need to use the brakes.I hadn't realised this. I'm sure that the speed limiter does control speed when going downhill - are you saying that this is achieved by using the brakes rather than using regen?
So maybe they are just talking about an exceptional circumstance where the regen wasn't able to hold to the limit because of a really steep hill?If the limit is exceeded when driving downhill, brake the vehicle with the brake pedal.
I think that only works with ACC. With the limiter the whole point is that it will prevent you going faster than the car thinks is the limit (unless you hard press).You don’t need to press kickdown to override an erroneous speed limit, merely press the accelerator gently to recover to whatever speed you desire.
Any passengers shouldn’t even notice.
The hard speed limit function is separate though?I think that only works with ACC. With the limiter the whole point is that it will prevent you going faster than the car thinks is the limit (unless you hard press).
I'll try and remember to have a look next time I go downhill with speed limiter engaged (I mostly use ACC so it may be a while before I check).can you see the green bar increase when it brakes under limiting? I've never tried it.
According to a user manual "You can interrupt the speed limiter function at any time by fully depressing the accelerator beyond the point of resistance. As soon as the stored speed is exceeded, the green indicator lamp will flash and an acoustic warning may sound. The speed remains stored in the memory. The speed limiter function is activated again automatically as soon as the speed drops below the stored speed."You don’t need to press kickdown to override an erroneous speed limit, merely press the accelerator gently to recover to whatever speed you desire.
Yes, that’s the ‘hard’ speed limiter that you can set to whatever limit you like.According to a user manual "You can interrupt the speed limiter function at any time by fully depressing the accelerator beyond the point of resistance. As soon as the stored speed is exceeded, the green indicator lamp will flash and an acoustic warning may sound. The speed remains stored in the memory. The speed limiter function is activated again automatically as soon as the speed drops below the stored speed."
The hard limiter by default follows the road signs too (but the limiter itself is turned off by default).Yes, that’s the ‘hard’ speed limiter that you can set to whatever limit you like.
I thought the OP was asking about whether the ID.4 reads and ‘obeys’ speed limits as it finds them, even outside of ACC, which it does as long as you also have predictive driving switched on. Those limits can be overridden via a slight pedal press.
It will always read speed limits and advise them on the small screen.
Do you mean if you’ve got the hard limiter set?The hard limiter by default follows the road signs too (but the limiter itself is turned off by default).
So, if you jump in an ID car, it will automatically read and advise of speed limits via a symbol in the steering wheel display.Well I'm suitably confused 🤣
I suppose what I want it to do is just limit itself to the speed limits on any given road, without any intervention from me.
I can set a limiter now on my Leaf but it's user defined and although the speed limits will show up, it has absolutely no bearing on the limiter behaviour.
I believe what you are asking for is an adaptive speed limiter that will do exactly as you have stated i.e. set your maximum speed to whatever the current posted speed limit is, and adjust (adapt) to subsequent changes there are (up or down).Well I'm suitably confused 🤣
