Add three phase charger in Kangoo ZE33 - or how to add range/increse charging speed
2733 Views 8 Replies 3 Participants Last post by  Dan87
I’m a happy owner of a Renault Kangoo ZE33. Despite the upgraded battery (compared to the 22 kWh) the range and/or the time of charging (7,4 kW) can be an issue.
May you help me pick out the best/most realistic solution when it comes to simplicity and cost :)
1) Add an additional Kangoo 33 kWh-battery in the load area and make it parallel with the original. Doubles the range, losing some space, also doubles the time of charge…
2) Install a new three phase charger (TC, Brusa?). Will cut the charging time to about 1/3, but can be expensive and complicated regarding CAN-bus programming, which I don’t know anything about. This alternative would be great if some repair shop in Sweden could do the job.
3) Install charger (and battery?) from other suitable EV with 22kW onboard charger.
4) Make a separate connection for fast charging the traction battery without using the onboard charger. CCS? But maybe this is as complicated as installing a three phase charger?
5) ?
I’m also interested in if someone know any repair shop with colleagues in Sweden, or a domestic Swedish repair shop with EV-knowledge.
Thanks in advance!
1 - 9 of 9 Posts
Are you interested in a CHAdeMO upgrade? It will work only when the car is in GO/Rdy mode.
Reactions: 1
Can be interesting. How?
Buy a kit. You'd have to install it.have you got the tools/ability?
Sent from my SM-A405FN using Tapatalk
I hardly not have the tools or ability but maybe I can get some help.
Can you advice any kit of recommendation?
Aren't there any kits for CCS?
For CCS it depends how rich you are, the current kits are around 5,5k £.
Chademo is more reasonable, but without tools and understanding of the system it's better to buy the install service.
Reactions: 2
Hi guys I’m basically waiting on the edge of my seat for someone with the ability and motivation on mine for a rapid charge or fast charge so if anyone is willing to do this for me give me a holler. My knowledge doesn’t extend far enough to take this on myself.
Where are you based Dan87? Get in contact, will do it.
Hi there I am based in the Peak District. Kind regards
1 - 9 of 9 Posts
