1 - 12 of 12 Posts
Had a slight front end bump in Zoe, now passenger headlight loose and bumper cracked - pics attached. Going to local dealer in Wakefield tomorrow for inspection but any adivce as to replacement parts, costings, etc would be welcome.
Renault Zoe 50
Can this plastic be welded like on motorbike fairings? It might be a cheaper option.
I would personally glue this together myself.
You can buy some really decent MMA adhesives that would do the trick.
I would stay away from cynoacrylates and epoxy types since they won't be as effective.
Cynoacrylates could melt the plastic and make a mess, and epoxies are strong but brittle, you'll want some give in the joint.
And if you decide to go for epoxy after all (see @squid_lemon s comment above), don't use fast curing. It is the more brittle variant indeed and the final strength is less than the slow (24 hour-ish) variants. Yes I love the stuff, especially the fast curing and use it everywhere, but it has it's limitations for sure.
Getting parts is a tough one but ebay is probably your friend. Not a very sophisticated comment I realize.
I would be a bit worried about the headlight; that's pretty critical and you may be requrired to replace the entire passenger side headlight. When mine were broken, they wouldn't let me take the car back on the road until the headlights got fixed. Not sure how much would be in the UK, but I had to pay 340 eur for each headlight.
For the crack, the service may suggest to replace it entirely, and that would be around 800 eur (the whole bumper).
Add labour costs, I gather 4-5 hours in total. That's to make the whole thing as brand new, which... it's a plastic crack, not worth spending 800 eur.
Have a look at
with regards the plastic mounting for the headlamp. There is a second one that is also designed to break / crumple that is harder to check. Probably means a new unit if you want it to last.
Labour is expensive - can be around £100 / hr
if it’s a headlamp mount it should be easy to buy for £30 or so but will cost £200 to fit maybe because the front will need to come off
you should be able to take the front off quite easily though
if a spanner monkey can do it then so can you - you just need time and patience and good weather
JJ
hi
get a headlight from eBay. start at around £80 and upto £150. search your year car etc.
Go to a body shop there was a guy from bradford area who had his bumper repaired. and repainted. but the search function is not working for me. Main dealer will be expensive.
Discussion Starter #9
Dealer checked the damage and gave a quote for £1610 to replace the front bumper, passenger headlight, passenger running light, labour and vat. Will look around for other options.
Thanks to all for replies.
1 - 12 of 12 Posts
