Sorry to bump, but did you ever do this? Getting my car Monday week and I've always had a full spare. Won't need it for local jaunts but worth it if touring.
Hi Sue - No I had already purchased the MG space saver set.
I not a big fan of the space saver wheels, but after coming from a car ( like many others today ) that only offer you a can of inflation fluid that will probably wreck your tyre or is useless for any large rips to the side walls, and the fact there is no room to carry a spare wheel.
Then just being able to carry a spare wheel at all, was an absolute god send I have to say !.
I also like having the max space in the boot, if you go for a full size wheel and tyre combo, you will loose a fair bit of depth in the boot floor.
Just some thing to consider ?.
The space saver is a decent compromise really, you get to keep all of the boot space and you can carry a spare wheel & tyre / wheel brace and jack of course !.
I have also got my type 2 charging cable curled around the outside of the space saver wheel.
If I want to hide items below the boot floor cover, I can just raise it up a notch and place things below it.
I like the flexibility this set up offers.
Check with your local dealer, but I can not see any reason why the wheel from the older HS will not fit the hubs on the ZS ?.
It is my understanding that the ZS does have the HS hubs fitted, where as all the ICE models have hubs with a different stud pitch.
The space saver kit that MG sell to suit the ZS EV was taken from the HS model.
Can you buy a bog standard steel wheel from the dealer ?.
If so and the price is reasonable, you just need a budget tyre and your sorted.
Oh ........ don't forget you will need a jack and wheel brace.
Get an after market wheel brace that can be extended, cheap enough to find anywhere, I have one in my boot.
