1 - 6 of 6 Posts
Electron Summit White NK13...110k 92.7 and rising
I've been using a piece of sponge to help stop my charge port door sticking closed. It worked well during the summer but I found that in the winter and especially in wet weather the sponge often became waterlogged and compressed and didn't really do the job properly any more.
So I've taken a different approach and obtained some small (M6) end stop screws that have a nylon tip and a hex key slot in the other end. I ordered 10mm long ones but had to grind them down so I would go for 8mm. Then I drilled and tapped an M6 hole in the plastic arm of the port (having first removed the flap cover) and screwed the end stop in from the outside. I found I could adjust the amount of protrusion very easily to provide just a little pre-load without distorting the hinge and so far it seems to work in all conditions.
140929
140930
M6 Plastic head Wave beads Screw POM Nylon Head plunger Grub Stop Buffer Screws | eBay
1 - 6 of 6 Posts
