1 - 6 of 6 Posts
· Registered
Or can a type 1 (vehicle side) to type 2 (charger side) cable that generally comes/came with EVs that have type 1 charging ports (e.g. previous Leafs or I-Mievs etc.) into the end of a type 2 charging cable?
I ask because we have a home charger with tethered type 2 cable and a Citroen C-Zero is being added to the family fleet.
I may very well be missing something (as well as my marbles) but the home charger has a type 2 “female” connector at the end and the cable that generally comes with such cars is type 2 “male” at the charger end, so that it can plug into untethered chargers at home and at public AC charging points, which are type 2 female.
· Registered
The type2 plug (on the end of your type1 - type2 lead) is shaped such that its too long to properly interface with the type2 socket on the end of a tethered or type2-type2 charging cable.
This is intentional to stop cables being daisy chained, which might create dangerous situations.
· Registered
Hyundai Ioniq 5 AWD
A confusing request. I think that you are asking if a loose type 2 to type 1 cable can be plugged into the output side of a tethered type 2 cable so that a type 1 car can be charged. If that is the question then 'no' is the answer.
But there are adapters available that will convert either way.
Type 2 - Type 1 Adapter - EV Charging Cables (cablesforcharging.com)
· Registered
Got it, I knew about the adapters but could not figure out what was different about them from the normal provided cable other than length, and being miserly by nature I didn’t want to spend out on one unnecessarily.
How safe are the adapters in comparison to a tethered type 1 cable. The C-Zero only draws 3.3kW I think.
· Registered
I suppose those adapters would also allow a vehicle with no rapid charging capability but type 1 charging only to charge from any AC tethered charger including AC rapids, though only at the vehicle’s standard rate of course.
Not sure I will bother with an adapter as the C-Zero does have DC rapid charging and as it has a granny charger we can use that temporarily until we get dedicated home charger with type 1 tethered, or an untethered charger might be the most flexible option.
· Registered
Kia Soul 30Kwh, 2018
You've probably resolved this by now but here's my input anyway.
I bought a Kia Soul (30Kwh - type 1) and had a 7kw Wallbox with type 2 tethered cable as there was a deal on - then bought the type 2 to type 1 adapter. This way I can cater for either type 1 or 2 from the tethered cable so if I swap cars / get visitors I should be able to cater for them. It's worked fine, no problems (that's torn it!!)
1 - 6 of 6 Posts
