Does anyone know if the Ampera headlight is a single unit or an outer shell with an insert ?
By insert, I mean something that looks like this-
www.centralbestellung.de
The Ampera headlight is an outer casing and then inside is a part which is a bit like a separate spotlight which I believe is a projector beam. In the advert above ( which appears not to be an Ampera ) the projector beam part is being offered as a separate assembly.
The reason is I have moved house from England to Germany and am required to convert my headlights for driving on the right. For a short visit no alteration is necessary but as I am moving here permanently I must change my headlights.
So far I have only been offered complete headlight units from the Opel dealer for 1500 Euros. If the light is built in two parts then I wont need the outer glass, only the inner projector beam and if its anything like the advert posted above I would be budgeting just a couple of hundred pounds.
HELLA 1BL 008 193-011 Halogen Scheinwerfereinsatz, Hauptscheinwerfer, Links oder Rechts
Hella 1BL008193-011 Abblendscheinwerfer / Hauptscheinwerfer Anzahl der Leuchtefunktionen: 1 Nennspannung V: 24 V Montageart: Einbau Ergänzungsartikel / Ergänzende Info: mit Glühlampe Leuchtefunktion: mit Abblendlicht...
