1 - 20 of 26 Posts
Hi all,I hope you're good.Anyone knows where i can buy a radiator for my 2012 Ampera?or maybe the part number if anyone knows it.Also i've lost all the engine coolant but the battery coolant level is ok.Is this normal?Thank you
I had my radiator replaced by Bellinger. They had to order it from Germany. I think it was difficult job as there are so many radiators mounted at the front. From memory I think there are 4 or 5!
When you do it a few pics would help others.
My receipt from Bellinger has a number next to the radiator.
022839735
Search on here for my post about water leaks. I'm sure I posted a schematic of the radiator layout which I found while googling.
Yeah that cost an arm and a leg to sort! Everyone needs the DIY grill guard installed ASAP
Answer - very! the radiator doesn't actually extend into that extreme end of the air-scoop, so keep sucking up the pheasants! All you need now is pheasant plucker to come along ... :)
Reactions: GJO
Discussion Starter · #20 ·
ha ha good one....so it is possible that it may not be the rad leaking....
1 - 20 of 26 Posts
