21 - 31 of 31 Posts
Discussion Starter #21
I know, it's a pain in the ass, mine is on the screen, and my (old) charger had no settings, but it was a bit hit and miss, and I found that I prefer the quality of the Nissan Leaf charger, so I use one of those now, it does exactly the same job.
mine's the revised model, 2014
Discussion Starter #22
Over the same 45 mile test route :
Tesla displayed 222Wh/m, actually used 255.0Wh/m
Ampera displayed 201Wh/m, actually used 234.8Wh/m
Ampera wins !
Could these results be due to the Volt/Ampy running the motor at its ideal rpm via the Voltec system which uses the sun and planet gears along with the second motor/gene to modify the gear ratio continuously.
I've a feeling under electric drive its effectively a 2 speed gearbox, switches in around 40 mph, you can feel it untangle the gears when you put your foot down, a slight hesitation before it takes off.
Did Porsche say they were the first with a 2 speed box....
That is not a gearbox. Just a transmission that switches between 1 motor drive (more power) and 2 motor drive ( more efficient)
If it is a steady fast drive I would suspect the Ampera. On a town route the Tesla.
The efficiencies are not scalar for all the speed range due to the Ampera's effective two speed option.
21 - 31 of 31 Posts
