They are the nicest looking home charging boxes, matches your front door nicely too!
Hope your not in UK as that looks like it's borderline with the regulations. Nice looking unit though.Got mine installed recently too. Very happy with it![]()
It is within regs. Thanks!Hope your not in UK as that looks like it's borderline with the regulations. Nice looking unit though.
BS 7671:2018+A1:2020 refers to the BS 8300 series, which states the EV socket-outlet must be installed within 0.75 to 1.2 metres from Finished Floor Level (FFL), with the top of displays between 1.2 and 1.4 metres from FFL.
Sent from my Pixel 3 using Tapatalk
That's good, just looked rather close to floor in photo and some might not be sure there is a regulation. They are definitely the nicest looking chargers.It is within regs. Thanks!
I was about to say 'no', then thought perhaps I should make sure.......Does your unit reflect a bar of light, red or green depending on status about an inch above the unit which is visible at night. View attachment 150184 View attachment 150187
I had not seen this on mine, but just checked and mine is the same, only shows part red line when I have my cable wound up, end socket on the right inside unit so only see red on right hand side at the top, see image attached, but if I take cable out I then get a full red line as in second photo…looks like led light is shining out top flap gap at the back…..not so noticeable on mine as on a red brick wall….Does your unit reflect a bar of light, red or green depending on status about an inch above the unit which is visible at night. View attachment 150184 View attachment 150187
