Yes yes so far I got it myself but I'm looking for a software solution because otherwise the interior lights will be disabled aswell. Thank you for your reply!If you open the door, right by the latch on the door frame is a rubber nipple looking thing, that's the door switch. Simple solution is stick it down with tape, or remove the switch and rewire it so it's permanently in the closed position.
