That was my best Jeremy Clarkson
Anyhow here is a link to a French Tuner that can sell you a tunning box for either e-Golf
A global exclusive for VW E-GOLF 2015 to 2020. This tuning, from several weeks of research, improves not only acceleration but also autonomy. Removing the pedal response time will allow you to enjoy sportier driving without compromising the reliability and proper operation of motor protection and battery.
For 85 kW (2015-2016):
The 0-100 mph goes from 10,4 sec to 9,5 sec.
For the gain of autonomy, here is concretely what is calibrated:
• Brake energy recovery is disabled from 8 mph and under. (Originally 13 mph and under)
• Brake recovery gradually reaches full regeneration power if load is less than 85 %. (Originally it's from 75 % load)
• The delay between acceleration and deceleration is reduced by a few thousandths of a second to enable recovery faster.
• Recovery limiter climbed to 350 NM instead of 300 NM.
• Power in eco mode is reduced from 70 kW to 60 kW.
• Power in eco + mode is reduced from 40 kW to 30 kW.
• The battery running range is extended from 3.5 % to 93 % instead of 6 % and 90 % for an additional 4.5 %
• The battery storage temperature is increasing by + 5°C: Unreserved operation is now between-25°C to 55°C instead of-20°C to 50°C.
For acceleration gain:
• The peak power of the electric motor is maximized at 90 kW and stable at 88 kW.
• Power limiters are disabled with the accelerator at 100 %.
• Speed limiters are increasing according to modes:
• Activation of launch control is now possible by simultaneously holding brake and accelerator at 100 %. The engine will be ready for take-off with 2 Kw upstream, giving you a few thousandths advantage second when you release the brake.
• The acceptable wheels slip difference with the anti-skating option disabled is now 30 mph instead of 0 mph.
Compatible software versions: 0 EA 90 730 9A, 0 EA 90 601 6A, 0 EA 90 601 6B, 0 EA 90 601 6C
For 100 kW (2017-2020):
The 0-100 mph goes from 9.5 sec to 8.2 sec.
• The battery running range is extended from 3.5 % to 98 % instead of 6 % and 96 % for an additional 4.5 %
• The peak power of the electric motor is maximized at 108 kW and stable at 105 kW.
Compatible software versions: 0 EA 90 730 9A, 0 EA 90 601 6E, 0 EA 90 601 6F, 0 EA 90 601 6AA
One price, $ 550 / tx
How to install programming in your e-golf computer? It's simple:
• Send computer in the mail ($ 25 for return shipping)
• Remotely with installation cable ($ 100 for deposit, $ 25 for shipping)
• With your e-golf at one of our resellers
Are you cold for your warranty? There are two solutions:
• Back to origin: If you need to bring your vehicle back to the original condition, it's possible. There's a fee for returning $ 50
• We offer you a 'plug and play' computer, so you will keep the original in an original state. Get price via private messenger.
* Fees may change without pre-notice. * *
- Normal: 156 km / h @ 12000 rpm
- Eco: 130 km / h
- Eco +: 120 mph
- Eco: 130 km / h
- Eco +: 120 mph
