Purchased a new Ariya Evolve 87kWh in Oct 2022. Probably worth stating at this point, that I’m very much new to EV’s and not massively technicallly minded. Charging to 330 miles full range until beginning of December, but then when charged to 100% has been showing estimated range of 220-230 miles. Being new to EV, means I drive mostly in Eco mode and with e-pedal on to help cope with battery anxiety so it can’t be related to driving patterns. And then two weeks ago, the 12v battery went flat, car couldn’t start and had to be jump started by RAC to get home. Still with Nissan and even the MasterTech is scratching his head as new 12v battery fitted but still only showing maximum range of 230. Just been browsing forums to see if anybody else has had a similar issue, and if anybody has suggestions for possible causes or issues
You really posted 2 points. 1. 12 volt battery failure and 2. Winter performance/ range issue.
Brief answers;
1. 12 volt battery failure is one of, if not the biggest point of failure with EV's. So, unless Nissan have found a problem with the car rather than the battery then this point will get little interest.
2. Now that EV's are more common, the newspapers have gone on and on about winter range loss. The Express, in particular, features it almost every other day. You have committed big money to an EV and some may ask unkindly how you could not know this.
This is my third winter with an EV. To give you a feel for the effect, I have drawn a very crude graph that will give you an idea. This is from observation and not from rigorous scientific study. Those with more experience than I may draw it slightly differently.
There are 2 primary issues and they are the influence of low temperatures on battery chemistry and, secondly, how much energy you use to keep warm in the car. Do you control at 23C with heated seats and steering wheel on or do you wrap up warm, turn the heating off and just put the heated seat on? The answer has quite a bearing on range.
Even in the South of England, we have had some nights pushing -10 Celsius; killers for EV's which effectively become almost unusable at -25C. Note that for some of the Scandanavians, I said "almost".
