1 - 3 of 3 Posts
Looking for some advice if anybody can help? I have been given an Audi E-tron Quattro 50 as company vehicle. I previously had a BMW 330e, for which I took the government grant and had a Rolec Type 2 with tethered cable fitted to side of house. It charged the BMW no problem for the length of time I had the car. The BMW was sold early February and I was temporarily given an non-EV car for a number of weeks before getting the E-Tron.
The first time I plugged the E-Tron in, it appeared to charge initially, but after around 5-10 mins, the indicator started flashing red and white. I then had to resort to plugging in with 3-pin plug or take the car down to our local railway station and plug in down there for a faster charge. I contacted Audi to see if they could assist, and they advised that there was a software update for the car and something mentioned in it about universal charging. I booked the car in for update and on returning home, plugged the home charger back in and it again appeared to be charging for the first 5 or 10 mins. When
I checked a short time later, the indicator was solid red this time. I had to use the manual release to get the cable back out and decided to try the 3-pin plug. It wouldn't recognise it this time and I had to use the manual release to get cable out. I took it down to the railway station and the type 2 wasn't recognised down there either and I had to use manual release again. The car has now been back to Audi and had a new charging unit replaced under warranty. I have no idea if the software update caused the issue or not. I also had the people who installed my original Rolec back out to the house and they have checked and it is still appears to be working as it should. I am now very reluctant to plug it back in the the car.
Anybody any ideas?
Renault Zoe 50
Rolecs are known for having RCBOs that fail early.
The good news is they aren’t expensive to replace with a decent version.
Can you remove the front cover and see if there are signs of burning on the RCBO?
The original
The original installers have been out in the last couple of weeks to check for any issues with the Rolec and have confirmed that it is fine! The first time I tried to charge with it, there sounded as though something was shutting on and off inside the head unit of the charger.
1 - 3 of 3 Posts
