1 - 3 of 3 Posts
I want to fit a charger in a location that only has a 20a supply. I can't upgrade the supply, or change the breaker etc.
90% of the time our plug in charger works fine, however I want to upgrade from a 13a to a 16a wall unit. Are there any units or devices around that will stop charging or cut supply to the charger when the other loads on the supply get above say 4amp ??
Is this possible??
Thanks, I'll look into zappi, do you know if you need to buy additional items, or wether the zappi charger does it out of the box.
1 - 3 of 3 Posts
