I have a kvaser CAN to PCMCIA Adaptor/Cable and a older laptop with WinXP
Yes there was a DTC code, do not remember now, it will get there when selecting drive or revere, if it is working correctly. Also should see DESAT with code 128 on one of the tabs in diag software. I would suspect atleast one IGBT is fauly if you see the same led-pattern. I like the 1200V version instead of 600V IGBT if possible and extra carefull to connect all the cable connectors firm all the way inserted to the IGBTs.Hello everyone, my question is for JTH: whether you had a specific error code when IGBT was faulty?
I lost the CAN connection with DMOC and the problem was with the small battery, like CMOS battery in PC. I replaced it and now connection is good, but red triangle still present. I compare the state of DMOC indication on board, and it the same, as in your pic. I have no DTC from DMOC, only the problem with balancing some cells in big battery. So, what do you think, my IGBT is faulty too?
