1 - 20 of 58 Posts
· Registered
Niro EV 3 in White
Approaching 5 months with my ID3 and I must admit I’m still not 100% sure I’m comfortable always driving in B, especially on motorways, from an efficiency and ease of driving perspective.
I kinda gravitated to B as a more natural fit to aid general braking but at times I still feel like it encourages a heavier use of the accelerator pedal with ‘the push it through claggy jelly’ feeling!
What’s your latest thoughts on best, most efficient, use of B and D after owning the car a while??
· Registered
VW design D as the preferred mode and I don't personally like the feel of B.
Albeit, this is based on my 20 min test drive, but I tried 5 mins of B and didn't like it. It seemed counterintuitive to pressing on. I can see it being of benefit only to people who drive with a lead foot on both the accelerator and brake, with no real anticipation of the road ahead, those who accelerate to a roundabout and then jump on the brakes rather than those who come off the accelerator early and brake lighter and later.
I think I'll be sticking with D when I get mine (which should have landed in Grimsby today after a 7 week wait in Emden).
· Registered
2020 e-Golf
Coming from an ICE automatic, I initially found B had a more familiar feel.
However I soon switched to just leaving it in D unless I know I’m going to need to slow down before the car ever could (such as stretches of road with speed bumps)
· Registered
2020 VW ID3
A few minutes during a test drive is not enough to understand the pros and cons of B and D.
Once you have the car, I suggest that you try again over an extended period.
That's what my wife and I did when we got our Golf GTE nearly four years ago.
I enjoyed learning the technique of using B properly and have continued to use it exclusively ever since. A little adjustment was needed when changing to the November 2020 ID3 but 2.1 upgrade takes me back to virtually the GTE technique.
My wife has stuck with D after her experiments. That means our brakes do not rust like they would if I was the only driver.
It's a very relaxing car to drive either way and I doubt that you could measure any difference in economy.
· Premium Member
After 9000 miles in mine, on mostly A and M-Way roads, I’m a confirmed D man now.
I can achieve better efficiency using anticipation, acceleration and coasting than ACC and I find B mode scrubs off hard won momentum unnecessarily.
In a city environment, or twisty B roads, or descending a big hill, B could be better, but I’m not a fan.
· Registered
I'll have another play when I get the car, but for me, I'm pretty sure I'd rather drive a car that's wanting to keep moving rather than trying to stop without your input. It's more economical to preserve your momentum and minimise waste rather than rely on a recovery system that is probably 60-70% efficient.
I'm presuming that using the brake pedal to a certain extent activates the regen rather than actually using the brakes and the actual brakes kick in under a firmer pedal press, as they would in B mode anyway - is that correct? If so, I'd think that driving in a way that generally preserves momentum in D mode would be noticeably more efficient than driving in an uneconomical manner and rely on "B" mode to save you some of that wastage.
I used to smash the combined mpg figures before stop-start massively skewed the figures. Even now, my missus averages 33mpg in our Polo GTI+ and I average 37mpg doing similar journeys. I get up to speed quicker than her but brake half as much as she does...anticipation of the road ahead.
· Registered
Niro EV 3 in White
Discussion Starter · #18 ·
Thanks, interesting replies. I’d thought they’d be more B fans, especially as youtubers like Teslabjorn always drive in B. But there is plenty to be said for a natural feeling freewheeling coast.
Of course ID3 typically has some intelligent regeneration assist in D which slightly complicates things I guess.
I think I’ll start using D more on faster roads.
· Registered
Sold ID3 Life 58kWh, Kona 64 kWh need to update the avatar :)
D mode for me all the time unless I'm in stop/start traffic but I turn off the intelligent regen assist by making sure its in normal and not eco, I find it annoying when I switch on sport mode and it acts as though it's in B mode.
· Registered
EV6 GTLineS RWD
I always drive in D, whereas my wife mainly uses B and switches to D on motorways and dual carriageways. Use whichever you are most comfortable with. I don't think efficiency is affected as much as by other factors (wind, rain, cold, etc).
I have found the same; D for long-distance cruising and NSL roads, B for stop-start stuff, but don't really stress about changing exactly as the road changes.
1 - 20 of 58 Posts
