I have a home Zappi connector for charging my 225xe. Over the last couple of months, the car has not registered as connected unless I move the cable around. wd40 Seems to help a little, or lifting the cable and draping it over the car flap.So might be corrosion and a loose connection. Before I change the cable, wanted to check. The two Communication connection points on the vehicle. Is the right pin further in than the left on everyone‘s car ? Mine is an inch further in.
