Cold and frosty morning, so I went to turn on the pre-heat from the app. I got an error message saying "12 volt battery voltage is too low. It will be recharged when you drive the car.". Surely the air conditioning is not powered from the 12 volt battery?? And why doesn't charging from the HV battery happen if necessary while the car is in the garage? I never had similar problems with the Leaf.
When I got out to the car, gripping the door handle to unlock the car did nothing! I had to use the unlock function on the key fob. After that the car started OK, the air con came on and I was able to drive the car without a problem. It was only a short journey to the local supermarket, and when I arrived the door handle functions worked normally and no more problems. The car is back in the garage.
So was it the low temperature (minus something overnight) causing it to think there was a battery problem, or what?
