Often new members have questions about charging and the attached document from BEAMA is quite good at explaining the options, sockets, cables, etc.
We see regular discussions on using only the portable EVSE (aka Granny) and the document contains following -
Ideally, all Mode 2 charging should be done using a dedicated circuit (i.e. any charging done at home). For new installations, when installing a socket outlet for EV charging, section 722 of the wiring regulations requires that a separate dedicated circuit is installed.
Info on BEAMA below
www.beama.org.uk
Info on BEAMA below
About
