1 - 10 of 10 Posts
Hey all,
Got a rear mounted bike carrier for the car (I know not the best option, but couldn't go roof, have a bad back and I can share the rack between the 2 cars and don't need 2 sets of feet for the bars) and was wondering about the electrics.
I was planning on getting something like this, leaving the socket in the boot and hoping the boot seal is flexible enough - done it on plenty of cars before this one. Anyone done this already and had any tips or anything to watch out for? Not sure if it has a socket to just plug into the wiring loom, so was going to use the blue cut in connectors on the lighting wires.
Thanks!
Chris
Discussion Starter #2
So, an update to this for anyone wishing to do the same.
The bike rack I purchased fits well. It's the 'Peruzzo Pure Instinct Rear Cycle Carrier'.
I chose this one as it fits my Outlander PHEV and the MG ZS EV. I was looking at roof mounted options, but to be honest, the eBikes are just too difficult to get on and off of a roof - I'm not that tall! Towing ball / flange mounted were also out, as the Outlander tows a caravan, and will not have enough weight capacity to have both the bikes and the caravan on the back.
I forgot to take a picture of the rack on the MG, but will do so next time we mount it up! The license plate is completely visible - the lights, however, are obscured by the bikes.
I found a PDF of towbar + electrics for the ICE version of the car (link), and it shows a 14-pin connector for the towing electrics. I know that the cars share a lot of pieces, so thought I would have a look in mine - a slim chance, I know.
IMG_20200712_092858.jpg IMG_20200712_092956.jpg IMG_20200712_093129.jpg IMG_20200712_095735.jpg
But as you can see in this last picture, I could not find the 14-pin connector:
132317
I did find the grommet to access the outside, should that be needed - although I am planning on just having it in the boot.
My next step is to look at splicing into the wires for the lights. I'll update when I've made some more progress.
Zoe Devotee
15kg individual bike weight limit? My Turbo Levo HT is 20kg. Not weighed the battery (I might do now i've though of it), but even at that its a weighty bike.
I bought a Thule 599 for the roof as it was the only carrier I could find with a 20kg weight limit. Most top out at 15-17kg. The Thule 532's I already had flex when you stick the Levo on even with the battery removed. Their limit is 17kg, which is fine for the kids bikes.
The bike carrier I chose (link) can have a weight of 22.5 per bike - 45kg total. My eBikes come in at just over 20kg without the battery. Wouldn't want to travel with the battery attached anyway!
Zoe Devotee
Ok! (y)
How do you keep the weight off the roof spoiler?
I mount it just passed the spoiler, seemed like a solid surface to me. Doesn't deflect with the bikes on. Here is a picture of where put the mounting pads:
132400
Sorry it's not a pic of the bike rack on, I'll get it when I next use it on the MG!
So, I finally got around to doing it!
I purchased a bypass relay for the towing electrics, some wire to power the relay, a 7-pin trailer socket and a fuse tap.
Running the cable from the fuse box on the passenger side was easy enough, the cable just tucked underneath the trim on the floor. Getting it to the driver's side of the boot wasn't too bad either, just took a long time to route it through!
136890
I peeled back the lining once more to reveal the wiring loom. The wheel arch looked like a good spot to stick the relay - I used some 3m VHB tape that I had laying around - wanted to avoid making any holes.
136891
It seemed to be happy there:
136892
Yes, I know... scotch-locks bad. But they are just so easy! All I had to do was carefully remove the outer sheath of the loom to expose the wires. I took both light clusters out and used my multimeter to test which wires did what. On my particular use case, some of the connections needed to be connected together, hence the wago. I had started tidying the wires, but decided to test everything before making it too neat! To deaden sound, it looks like MG just stuffed insulation into a plastic bag and wedged it in:
136893
I was worried about just trapping the wire at the bottom of the boot, but it seems fine (tested before all of this to see if I had to make any holes). There is actually enough give that the cable can move in and out without too much force.
136894
Success!
136895
Hopefully this helps anyone who is looking at something similar. This solution works for us, it's been tested a few times now and works well.
Discussion Starter #9
That's the one photo that I forgot to take! I'll update once we use the bike rack again!
1 - 10 of 10 Posts
