1 - 12 of 12 Posts
Picked up a new 40kwh Tekna today, an hour later after returning to the car, the centre screen did not come on. Turned off car, locked tried again, same thing, pressed every button known to man, still as dark as the night. Back to dealer, no radio, no maps, no cameras etc, several technicians and calls to Nissan, nobody has heard of this, has this happened to anyone out there? Cheers.
2014 Model S
Check the user guide in case there is some way of turning off the screen or turning the brightness right down as you may need to guess where the touch screen buttons are to get it back again.
I'd take out the SD card altogether. Normally the head units then complain there is no SD card. Also unplug any USB devices plugged in anywhere.
I wouldn't be very impressed with a brand new car behaving like this at all.
UPDATE: Thank you for all you replies, I've googled this overnight and can't find it happening either. The dealer had the unit out, power is going to it and power is getting to the on/off switch but that's as much as they can tell. It actually died on the Nag screen at start up, with out accepting that you can't progress, so my thinking is its the boot sector of the drive that has failed.
Nissan UK want the unit back to investigate, so they have dispatched a new one, hopefully Wednesday, I don't think they have heard of 24 hour couriers! In the meantime the dealer has leant me a petrol car, so not used to using that pedal on the left, I think its called the brake. Just to rub salt into the wound, as they were handing over the keys to the ICE, they drove my old 30kw Tekna past me off to its photo shoot, that one never let me down!!!!!!!!!!!
Switched on my 2020 40kWh Leaf N-Connecta Leaf this afternoon and was greated with a blank centre display. Rebooting the car had no useful effect. Everything else appears to be working fine. Does anyone have any ideas or is it a case of handing it to the dealers?
The plot thickens. Just went out to the car and powered it up. Display is now working fine! Loose electrical connection? Software bug? Mid software update? I guess it will be 'interesting' to see what happens over the next few days.
I have Nissan Leaf 9 month old. No issue until now. Had same issue yesterday. Suddenly screen blank but car running ok.
I thought this as a computer issue with crap old windows 98 kind of software.
so switched off car and then restarted it. No use.
Then I switched off again. This time connected to EV charging cable and charges for 2-3 minutes. Disconnected it and restarted the car.
everything is fine and working.
seems like a software bug.
These car companies are not like Tesla which is technology company making car.
My 2020 Leaf's touch screen would very occasionally reboot a few miles from home. It always came on to begin with, but I never did find a reason.
1 - 12 of 12 Posts
