1 - 7 of 7 Posts
Whenever I receive a call via Bluetooth I find the call volume is quite low, so I have to crank volume up on the infotainment system to hear the caller. That's not a problem in itself, but when the call ends the radio blasts loud as the volume has been turned up.
Anyone have similar experience and found a way around it?
Maybe this is helpful - explains how to crank up phone level for bluetooth link
Zoe Devotee
Isn't it the case that bluetooth takes initial volume level from your handsets setting. No doubt you've got your handset turned down low (most folk I know turn volume rocker down to zero then vibrate) so in bluetooth by default its at minimum volume. On answering a call in car its at lowest setting so you crank up the volume (which never seems to get loud enough, because its level 1 on the handset) and then the radio is full blast on ending the call because you just cranked it up to max.
Try turning up your handset volume to 50% then receive a call.
Discussion Starter · #7 ·
Sandy, phone volume is all the way up (I did check that before posting)
1 - 7 of 7 Posts
