Hello.
Has anyone figured out the off-peak charging for the BMW 330e (first generation)? I have had the car (2016 330e) for over a year but have finally got a smart meter with the Octopus Go tariff (highly recommended, PM me for a £50 off link if you want to switch to them). It gives 5p/kWh overnight from 0030 to 0430. (With an EVBox charger).
This is what I’m trying to do. I generally leave around 0630 and I want the car preconditioned, and with a full battery. The charging pattern would ideally be to fill the battery between 0030 and 0430, with a small top-up as it pre-conditions around 0615-0630.
I haven’t figured out how yet.
Attempt 1) I set the off-peak from 0030 to 0700 so that it can still top up while it pre-conditions, and the departure time at 0630. But then, it only starts charging around 0400 and I mostly miss the cheap time.
Attempt 2) I set the off-peak from 0030 to 0700, and two departure times: 0430 and 0630. But then, it preconditions twice (once in the middle of the night), not ideal.
I have some other ideas but has anyone figured it out? I guess that if I fixed the off-peak times 0030-0430 it would precondition from the battery for the 0630 departure and I would start with a depleted battery.
I have some other options to play with in the wall box charger timer but haven’t gone there yet.
I’m sure others have the same issue, has anyone figured it out?
