1 - 6 of 6 Posts
Hi,
Does anybody know what the temperature gauge should read in normal operation?
It currently sits at just under 120C on the gauge. Just wondering if this seems a little high or sounds about right?
Thanks.
Audi eTron 55
Google says...
Engine oil temperature should be somewhere around 250 F. One needs to keep in mind though that BMWnow uses an electronically controlled thermostat so the DME can manipulate the coolant temperaturebased on different driving scenarios to help acheive better fuel efficency and engine performance.
...and also that BMWs usually display oil temperature, not water temperature.
Thanks for the reply.
I should have stipulated that it was actually the water temperature I was after.
I have a water temperature gauge that when the car gets up to normal operating temperature the gauge reads approximately 110 degrees
Does this sound about normal?
Audi eTron 55
Yes - it's a pressurised system so will operate at above 100 degrees C. As long as it's steady temperature and mid-range it's fine.
1 - 6 of 6 Posts
