1 - 20 of 22 Posts
New model, same shape as the Pure, with extra management functionality.
Product Gadget Technology Electronic device
Press release:
Munich. With the BMW i Wallbox Pro – the second home charging station in the BMW i 360º ELECTRIC portfolio for electric and plug-in hybrid vehicles – zero-emission electric mobility is set to become an even more attractive option. The BMW i Wallbox Pro offers a faster charging rate than the BMW i Wallbox Pure and even more user-friendly operation, as well as innovative options for vehicle charging with home-generated electricity and smart home integration. The BMW i Wallbox Pro is available as an Original BMW i Accessory. Optionally an installation service is also provided, which offers fitting and connection of the BMW Wallbox Pro in the customer’s home or garage by qualified experts.
With a charging rate of up to 7.4 kW, the BMW i Wallbox Pro supports very fast charging of electric and plug-in hybrid vehicles. In this case the high-voltage battery of the BMW i3 takes less than three hours for an 80% charge. The BMW i Wallbox Pro is also compatible with other makes of vehicle equipped with the European Type 2 standard connector.
The BMW i Wallbox features the familiar BMW i design and aesthetics. The front of the high-quality plastic housing has an anthracite special-effect finish with black detailing and chrome along with highlights in BMW i blue. Reflecting the sustainable ethos of the BMW i brand, the BMW i Wallbox Pro is produced from environmentally friendly materials.
The BMW i Wallbox Pro is operated using a 7-inch colour touchscreen display, which offers optimised control and monitoring of the charging process and allows users to choose their own individual settings. The screen can show how much charge has been delivered to the vehicle so far, along with details of previous charging cycles. LED fibre-optic strips at the sides of the wallbox indicate the current charge status and are visible from a considerable distance. Information about the charging status can also be remotely accessed from a smartphone or tablet by using the BMW i Wallbox Remote app.
The BMW i Wallbox Pro provides an administrator function that can keep a charging history for different users. Up to three user profiles can be set up, e.g. for accounting or billing purposes. For example, private and business-related electricity use can be recorded separately. Details of electricity consumption for a particular user account can also be forwarded by email if desired.
A proximity sensor activates the BMW i Wallbox Pro when motion is detected. The charging plug can be picked up and connected to the vehicle socket using just one hand. Further user-friendly features include the 3.5-metre charging cable. The cable’s entry point towards the top of the wallbox protects it from contamination and makes it unnecessary to coil the cable.
The BMW i Wallbox Pro’s integrated load management system delivers the maximum available current when charging. At the same time, overloading is prevented by reducing the charging rate as necessary during peaks in household power consumption. A clear readout on the touchscreen shows how much power is being drawn from the household electrical system at any given time.
Assisted by its intelligent charging functions and the optional energy meter, the BMW i Wallbox Pro is unique among home charging stations in the extent to which home-generated electricity can be integrated in the charging process – for example electricity from a home solar system. This option is used whenever possible. The intelligently integrated wallbox detects the availability of solar power and immediately uses it for charging. If no home-generated energy is available, power from the grid is used instead.
If the BMW i Wallbox Pro is integrated with a smart home system, the efficient charging functionality can be extended even further to reduce peak loads on the household electrical system and optimise the use of home-generated electricity. Via the touchscreen it is possible, for example, to connect the wallbox to the smart home system myGEKKO. Up to eight smart home functions can then be controlled from the wallbox display, including activation of outdoor lighting. It is also possible to display a weather report on the touchscreen, showing current temperatures, daily maximum and minimum temperatures, frost warnings and forecasts for the coming days.
The BMW i Wallbox Pro is an Original BMW i Accessory and is available in all European markets. At the end of the year it will also go on sale in markets in Asia, Africa, the American continent and the Middle East. The BMW i Wallbox Pro can be installed both in closed garages and in covered outdoor areas.
Changed to the full press release instead of a link. :)
Is that a technical point or one of ettiquette, Paolo?
The app is on the app store now, interestingly there is a picture of what appears to be a 2 series tourer on the select car page. Do Schneider know something we don't?
The 2SAH shares a platform with the new 5 door Mini. That platform is reported to have been engineered with Electric power in mind. Given that one 2SAH has the same engine as the i8 (detuned though) and when I asked someone who knows whether we could see a Mini EV soon his poker face spoke volumes, I'm confident that there will be more BMW/Mini plug-is along soon.
This does smack of "New Apple Teasmade leaked in iOS12 code update"!
Discussion Starter · #10 ·
Bit odd, the press release saying that the Pro charges more quickly than the Pure, and then quoting 7.4kW, which the Pure supports also?
Having dealt for several years with BMW (MINI) press releases they quite often used to lose quite a few things in translation and/or have inaccuracies that you wouldn't spot if you didn't know better or what you were looking for. This may be one of those things.
Discussion Starter · #14 ·
According to BMW on Facebook, the Pure doesn't supply 7.4kW in all territories the Pro will.
Interesting - was not aware of that. The 40 odd that we've fitted in the UK all run at 32A.
Banned
I suppose that the Pro can be 'smart' about usage and only ramp up when it knows there is available capacity, which the Pure couldn't do.
The good news is that they appear to have kept the shelf - we will still have somewhere to stow our driving gloves while we perform our charging duties. The bad news is that they've taken away the cupboard (yes, that is what is in the middle of the Pure). Where will I keep my shampoo now? (Seriously... if you have one of these, what *do* you keep in the unlockable cupboard?)
Leaf 40
Stupid question perhaps but are these ok for external installation? As I've got the tethered Type 1 charger I'm going to need to replace it if I order the i3 and ours is mounted on an external wall.
Banned
Either way they seem to be good looking units, relatively speaking.
Some things are great, others not so.
Positives:
  • Nice slinky cable that has a quality feel and shows no sign of twisting.
  • Supported by BMW so when there is an issue they are all over it.
  • The shelf is actually quite handy, I often dump stuff on it while messing with cables.
Negatives:
  • Cable management isn't great. You either mount it high enough on the wall that the cable just droops down, or you attempt to wrap the cable around the entire unit and hope it doesn't fall off. (It doesn't, but not ideal.)
  • It apparently looks like some kind of door-entry phone, at least according to one delivery driver who tried to call me on it.
  • I still have no idea what to put in the cupboard.
1 - 20 of 22 Posts
