Hi all,
A few times now, the boot has got stuck between open and closed on the safety catch. The car bings at you when you select Drive, so you get out and try to open it to close it... but the boot release button doesn't do anything! You can get out and try to lock the car but it refuses because the boot's only partially latched, but it still refuses to open.
So far the only solution we've found is to walk away, wait 5 minutes for it to shut everything down that it can, then come back, press the unlock button (even though it's not locked) and then you can press the boot release.
This is really annoying! Anyone have any ideas? It sounds like the car isn't sure whether it's open or closed, with the safety bing system saying it's open, but the "He's pressed the boot release, what do I do?" system saying it's closed
I'm fairly sure this is linked to one of the ways the car can drain its 12V battery as at least three times when that happened, the boot was mysteriously in this halfway position (even though we're sure we closed it properly), but time will tell as I've now had the BMS update.
