1 - 14 of 14 Posts
Hi there,
I've just moved to a new house in a fairly rural location, I'm looking to get a BP Pulse home charger installed (included as part of my Zoe lease). However the reception for O2 and Vodafone is very poor here - I've read that these are what The BP Pulse units use to connect their smart services. Can anyone advise if this would be an issue?
My other option is to go for an untethered BP Pulse wallbox + an Ohme type 2 cable to use it's smart capabilities (I already have an Ohme granny charger working well here). I'd like to leave the cable attached to the wallbox for convenience so I guess I would need to lock it somehow. Is this a sensible option?
Thanks!
Hi Freddy,
Thanks for the suggestion but I'm hesitant to go that route as I'd rather not pay for the hardware + installation (on top of the Ohme cable) when both would already covered by my car lease. Do you not think the other options are viable?
Hi Freddy,
Might be worth a read of the posts describing satisfaction with BP Pulse.
Free or Reliable. That might be the main factors in the decision.
Fair point. I'm still inclined to take the chance with it, even if only using the "dumb" parts of the charger. If worst came to worst I guess getting an electrician to remove the wallbox and replace with a commando socket would be a fairly quick & easy job (please do correct me if I'm wrong here)
I'd love to hear if my other options of a tethered or untethered unit + Ohme cable would make more sense in this scenario?
It sounds like you are going into it with your eyes open. And if you have a chat with a sparky re worse case scenario of swooping out for a CEE socket looks like you are covered. Good luck😁
Hi there,
Thanks!
Screw the ohme box to the wall for security it's the same as the fixed unit use some security screws they are a devil to remove without the right tool
Sent from my POCOPHONE F1 using Tapatalk
Hi there,
Thanks!
Hi Jim, Two quick questions: Did you get the Homecharger installed ? Does it connect sucessfully ? Do you know which network Its on which network is it on ?
Discussion Starter · #10 ·
Hi Rixy, I did get the homecharger installed, after many painful months of chasing BP (I would DEFINITELY recommend choosing a different supplier if you can) and all has been working well since. I've never really used the smart services though as I've been able to set the charge timings etc through my cars app.
Yes it did connect eventually, though it took a while to come online. They put in a mesh module to allow it to piggyback off any other nearby connections - I'm not 100% sure if that is what made the difference, but seems to be reporting data well. I believe these smart units all use the O2 network which is pretty flaky round here.
Hi, I'd be really interested in what the 'Mesh Module' is ? Can you post a photo? Just as you find you have spent many painful months chasing BP to get it to work , I have spent many more painful months trying to communicate to PB Pulse the benefits of our Anynet SIM - which would allow communication on any mobile network available ! They don't have phones - they don't reply to emails. If any BP Pulse folks are monitoring this forum I'd be delighted to hear from them !!
Discussion Starter · #12 ·
Office equipment Gadget Office supplies Gas Font
This is the mesh module. I'm not sure of the full technical details but I think it searches for other units in the vicinity (a few hundred meters?) and can connect to the cellular network via them if they have better signal. I'm not sure if ours is connecting using the mesh or gets enough cellular signal once in a while to send off the usage data, but seems to be working ok.
I did ask about the network they use (we've got really strong EE signal here) but I don't think there's any way to change this, apparently it's fixed for all these units.
It looks like the Toshiba unit uses Zigbee to communicate with other devices locally ; The HAN is a Home area Network ( for in home displays etc ) and the WAN is Wide area Network ; Gas is probably the gas meter! An Eseye Anynet SIM would work with O2 or EE as its multi network. I have to declare an interest in Eseye at this point ! Thanks for Posting Dave
ive had a nightmare with bp home charger wouldn't connect then finally when it did it allowed my schedule of charging between 00.30 & 04.30 but one day I wanted to charge outside these hours but the override didn't work and it lost communication with bp but stuck on the schedule charge.
it took them 3 months to get it to the right technical team and they blamed poor signal they advised me they use Vodafone 2G network cannot believe bp's using 2G only, they came replaced my unit so I could charge anytime but still blame poor signal I live less then 200m from a Vodafone & o2 mast get full 2G/3G&4G signal with Vodafone around here
a subbie came out to replace it I had a little rant at him about how terrible bp are and he said you should try working with them 😂
anyway ive now decided to ditch the bp charger and get the Ohme home pro
its no surprise they ranked near the bottom on surveys for there home chargers just like there public chargers
1 - 14 of 14 Posts
