1 - 4 of 4 Posts
In this post, I mentioned that I'd collated the material prices for some budget charge point options: Getting a home charger installed
Rather than clutter that thread up with off-topic stuff, I though I'd try and put the prices in a new thread. I've made some assumptions about the installation, just to simplify things a bit. I've assumed that the supply is TN-C-S/PME, so the charge point must have open PEN fault protection. I've assumed that the cable run from the meter to the charge point is 10m. Finally, I've assumed that a socket, either a Commando or a Type 2, is acceptable (tethered charge points are a bit more expensive).
These prices are only for materials, and don't include labour, as that will vary a bit depending on region and the ease, or otherwise, of running cables etc. I've included VAT, and tried to cross check the prices as best I can, but it's entirely possible that I've made some errors. I have a list of supplier websites I've used to get prices, and could add these if they would be useful to anyone.
Finally, installing a charge point is not really a DIY proposition unless you are a competent person, understand everything in BS7671:2018, have the required test gear to be able to ensure the installation is compliant and safe, and, in England and Wales, you obtain building regs approval under Part P. Failing to do the latter is a criminal offence, that can carry a hefty penalty.
The first options considered are to install a 32 A commando outlet, for use with a suitable portable EVSE
Option 1 - Commando installation with earth electrode for open PEN protection
Henley blocks
£26.00​
Tails
£10.00​
4 mod enclosure
£25.00​
DP Type B RCD
£114.00​
40 A MCB
£3.00​
SWA cable glands
£6.00​
10m 6mm² SWA
£25.00​
cleats, sundries etc
£10.00​
Earth rod, clamp, box, cable
£40.00​
32 A interlocked Commando
£40.00​
TOTAL
£299.00
Option 2 - Commando installation with Viridian connection unit for open PEN and DC RCD protection
Henley blocks
£26.00​
Tails
£10.00​
Connection box with RCBO, DC earth leakage, open PEN protection
£246.00​
SWA cable glands
£6.00​
10m 6mm² SWA
£25.00​
£10.00​
£40.00​
TOTAL
£363.00
The remainder are all based on using versions of the Qubev non-tethered charge point (only because it's probably about the cheapest available)
Option 3 - Non-tethered charge point installation with earth electrode (no integral DC protection)
Henley blocks
£26.00​
Tails
£10.00​
4 mod enclosure
£25.00​
DP Type B RCD
£114.00​
40 A MCB
£3.00​
SWA cable glands
£6.00​
10m 6mm² SWA
£25.00​
£10.00​
£40.00​
Qubev basic charge point
£225.00​
TOTAL
£484.00
Option 4 - Non-tethered charge point installation with integral DC protection
Henley blocks
£26.00​
Tails
£10.00​
Qubev enclosure with RCBO
£34.00​
SWA cable glands
£6.00​
10m 6mm² SWA
£25.00​
£10.00​
£40.00​
Qubev basic 18th Ed charge point
£299.99​
TOTAL
£450.99
Option 5 - Non-tethered charge point installation with integral DC protection plus Viridian open PEN fault box with RCBO
Henley blocks
£26.00​
Tails
£10.00​
Viridian enclosure with RCBO, open PEN protection
£158.40​
SWA cable glands
£6.00​
10m 6mm² SWA
£25.00​
£10.00​
£299.99​
TOTAL
£535.39
Discussion Starter · #2 ·
Updated as when I wrote the above I hadn't realised that Qubev were really Rolec in disguise. Frankly I would never touch a Rolec product, because of the proven poor quality of some of the components and materials they use, and as the Qubev seems to be a budget version of the Rolec I doubt that it uses better quality parts.
In the tables below I've costed the materials to install a permanently wired in Ohme charge point (not the Commando version, for that use the Commando outlet costs above and add the cost of the Ohme).
Option 6 - Ohme charge point installation with integral DC protection, wired as a TT installation for open PEN fault protection
Henley blocks£26.00
Tails£10.00
Enclosure with RCBO£34.00
SWA cable glands£6.00
10m 6mm² SWA£25.00
cleats, sundries etc£10.00
Earth rod, clamp, box, cable£40.00
Ohme permanently wired charge point (via Octopus)£199.99
TOTAL£350.99
Option 7 - Ohme charge point installation with integral DC protection, plus Viridian open PEN fault box with RCBO
Henley blocks£26.00
Tails£10.00
Viridian enclosure with RCBO, open PEN protection£158.40
10m 6mm² SWA£25.00
TOTAL£435.39
1 - 4 of 4 Posts
