1 - 7 of 7 Posts
Hello,
I plan to build an additional battery pack in my C-zero. THe method i plan is to paralell the main contactor of the original traction battery in the extender pack. For the i-miev I found the battery the wiring connections, but for c-zero I cannot find it. IT would be nice to see which EV-ECU connectors regulate the pre-charge,+,- relays...
Thank you!
Hello,
Thank you!
The CZero is the same as the iMiev ( except for difference in number of battery cells and different service interface). Wiring will be identical.
HEllo,
unfortunatelly not - while the wiring may be the same, the EV-ECU connectors are different - hence the I-miev wiring cannot be mirrored to the c-zero...
HEllo,
Post a copy of the specific wiring diagram for the iMiev that you are trying to find.
I assume you know that MyIMIEV covers all triplet variants and has a proper technical section.
Hello Tibor, Witam !
Perhaps you have already seen this, but there is a thread on another Forum about adding a second i-Miev battery pack:
The second post on that thread contains a link to a further 18-page thread:
In addition, there is this thread, based in Denmark:
Hello,
unfortunately, the i-meav and the c-zero EV-ECU is not the same - i mean: different connections, different pin-out. I know the I-miev EV-ecu connector pin-out, but 105,106,107 connectors has different function in the C-zero than in the I-miev. Hence i need the C-zero battery wiring circuit.
Does anyone by any chance has it for the C-zero?
Best regards!
Dear All,
I am sorry for my mistake. Yes, the c-zero has the same wiring as the i-miev. It was my mistake - took a while to get hold of the proper wiring diagram.:)
Best regards,
Tibor
1 - 7 of 7 Posts
