I have a bit of 'overspill' so it doesn't drain the battery prematurely.And still exporting 😁
I would have got the Powerwall if I could have. Then I could go off grid.Have the same set up but have a Tesla Powerwall also. The myEnergi products with Zappi and Eddi and Harvi (with hub) are excellent and tie everything together. Cost a bit but saving us loads of money. And now the energy price rises are being felt, the payback from the investment will be much sooner than expected. I would recommend storage batteries (doesn't have to be the Tesla PW) to make it all even more worthwhile.
I thought most battery systems could be configured to run off grid.I would have got the Powerwall if I could have. Then I could go off grid.
Mine can. It’s just the Powerwall would be bigger capacity.I thought most battery systems could be configured to run off grid.
Yeah. There are several different implementations but pretty much all hybrids inverters can provide power in the eve of an outage.I thought most battery systems could be configured to run off grid.
It's pretty hard to go completely off grid. In the middle of winter the input from the PVs is really tiny and not enough to run a house, even with the help of batteries.I would have got the Powerwall if I could have. Then I could go off grid.
Same here really.When we got ours, they actually were the best value for money £ per kWh. They are still by some considerable margin, the best selling storage batteries and have been totally reliable with excellent back up/data capabilities. Add in real world things like the Gateway, power cut back up protection and one of the few if not the only home storage batteries that can output at 5kW (with peak maximum of 7kW) then it means that we are off grid 99% of the time from mid March to mid October. And that’s with 2 EVs now. We do have a large solar install though. For most people with other brands of battery, even putting on the kettle, will mean (a tiny amount) of grid use! The myEnergi stuff helps balance it all out, keep an eye on and makes stuff easy to control from the app. And as the OP shows , it helps to save on gas use as well, as the extra solar helps to turn on the immersion heater to warm our water tank up.
And the best advice I can give is not to go via Tesla but contact one of the few Tesla installers (we are based in the uk) directly to get a quote. Tesla have remained very strict who gets to install them. In terms of training etc. No cowboy installers! That saved us a lot. May well be different now. I think there is almost a 1 year wait for a Tesla battery now if you want one due to the energy price crisis/demand out stripping supply.
I guess there is an increased fire risk with the chemistry Compared to the new style battery chemistry. But it is pretty much the same chemistry in all EVs at present. And Tesla themselves are the leaders in the new EV battery tech! Will wait and see what the PW3 brings. (We have the PW2).
Progress and tech never stands still.
We have been holding off as well, on the basis that when we get a full EV it should be at home enough of the time during the day to soak up the spare solar.Same here. My installer could do it for a little less than the original install but we would be looking at end of year until he has the time! As we also export a lot after the battery fills and we are at work and the cars are not on charge. However I was thinking when CCS enabled V2Home comes online then our EVs will be the storage batteries so may be no real need to get the 2nd Tesla battery. Still deciding. And V2H still some way off I suspect although Chademo EVs/technical spec allow for this right now with the right equipment.
What they don’t tell you is all the other hybrid systems need a gateway installed, unless it’s a permanent off grid system.A lot of Powerwall owners seem to promote that it can provide supply during a power cut. Maybe they weren’t told that every other battery inverter on the market can also do this.
