A little more info might help. Just what is the Inverter working off? The 12v sub system or the HV battery and in which EV? Are you sure this shouldn't be in the power fuel alt energy forum.
1200 Watts at the usage point would be 1260 to 1320 watts into the Inverter as you have to allow 5 to 10 % losses possibly more on a bad design. Motors though can have a startup draw which may causing tripping. A 600 watt induction hob sounds low power. Our portable one is 3kW peak though when running can be just a few hundred or less when keeping warm.
