Thanks for that quick reply, can always rely on this forum!Only to be used in the event of an accident by first responders. It is to let firefighters know where to cut the 'main' cable.
That definitely shouldn't be sticking out like that. As BruceH said, it should have been tucked under the plastic panel. You can do that yourself as that panel comes off with a bit of a pull. Something they missed in the quality control... like many other things.Thanks for that quick reply, can always rely on this forum!
Good job I didn't cut it![]()
Are you sure? Mine doesn't stick out, and likewise, all the M3's that I've seen also don't have anything like that sticking out. But all the M3's that I've seen are 2020 models so perhaps they've changed it recently. In any case, I guess it doesn't matter either way then.I'm fairly sure it should be sticking out. The whole purpose is to show emergency staff where to isolate the battery. If you tuck it away it won't be apparent. It's been sticking out in all the Tesla's I've seen.
Probably less of an issue now as most fire crew are supposedly given info on how to isolate batteries, but I'll definitely not be tucking mine away out of sight.
Yeah that's my understanding too, it is supposed to be sticking out, maybe not quite as much as in that photo but a little bit should be visible at least.I'm fairly sure it should be sticking out. The whole purpose is to show emergency staff where to isolate the battery. If you tuck it away it won't be apparent. It's been sticking out in all the Tesla's I've seen.
I would expect them to isolate before cutting. If they didn't know how to isolate I expect them not to cut until after 'the call'.If you’re in a bad crash they cut the roof off to get you out. Then call someone who knows how to isolate these things - like a Tesla mechanic.
I agree, I think some are not giving firefighters enough credit here, they are highly trained pros and have access to significant data that manufacturers provide, lots of info here First Responders | Tesla UK. IMHO it makes minimal difference if label is showing, I'll leave it tucked away where it is; if it was deemed a safety critical function then manufacturers would be fitting a much more easily identifiable bright orange access hatch or similar that couldn't possibly be missed.Firemen do know what to do, if you're trapped in the car and they start chopping it up to get you out they'll need to find this and isolate the car.
Happy to be proved wrong, but I doubt their training extends to every single make and model of EV.I agree, I think some are not giving firefighters enough credit here, they are highly trained pros and have access to significant data that manufacturers provide, lots of info here First Responders | Tesla UK. IMHO it makes minimal difference if label is showing, I'll leave it tucked away where it is.
I think I agreeI'm a bit surprised that there's this much discussion, it's a tag under the bonnet ..... it's only purpose is to clearly identify the location of a safety feature. Surely the answer to "should it be hidden or not" is that there is no reason or disadvantage to it being visible, and there is a possible disadvantage in some circumstances (which may, or may not, only have a very slim chance of happening) to having it hidden. So leave it out.....
The FB WILL know what to do, where to cut and how to open the bonnet in an emergency. They also know there is a cut point in the side rear window to kill the power in the event of a roof chop.In reality the firemen won’t have a clue what to do, and will just stand well back until the fire has gone out.
Bear in mind they have to open the bonnet to see the tag. If they got that far they probably know what they’re doing.
